Hi guys, I have a spec thread somewhere on here and I'm literally incredibly close to buying but I want to clear up a couple of things first.
I'm using my iMac 27" (late 2009) as a display. The input is a Mini DP and the res is 2560x1440. I want to know how this will limit my card choices. Reaper on my spec thread said I could use any adapter i.e. HDMI to MDP since HDMI can support that resolution. However, I just found this: http://www.cultofmac.com/video-27-inch-imac-in-action-as-external-monitor/20355
The bit I'm looking at is the second line down where it says "but will only work with devices that output DisplayPort video, like newer MacBooks."
I'm guessing this means if I used my iMac as a display my card has to have a DP output yea?
There was a thread on the Apple forums where people have been doing exactly what I intend to and I noticed no mention of other outputs from GPUs other than DP or MDP.
Anyway, if you could help me clean this up I'd be really grateful.
Regards,
Mike.
Regards,
Mike.
