CPU: i7 2600k
Motherboard: Asus P8Z68-V LX
Cooler: Cooler Master Hyper TX3
I am looking to squeeze a bit more life out of my CPU purely to save money. I have never overclocked before.
With that in mind I suppose I should aim for between 4 - 4.5ghz?
From what I can gather I should just change the core value to 40 or 45 and leave the voltages alone. Is this correct?
Or should I go with something like this; will it be stable?
Ai Tweaker > Ai Overclock Tuner: Manual
Ai Tweaker > BCLK/PCIE Frequency: 100.0
Ai Tweaker > Turbo Ratio: By All Cores
Ai Tweaker > By All Cores (Can Adjust in OS): 45
Ai Tweaker > Internal PLL Overvoltage: Disabled (this is not needed with an overclock this small)
Ai Tweaker > Memory Frequency: DDR3-1600
Ai Tweaker > iGPU Max. Frequency: Auto
Ai Tweaker > EPU Power Saving Mode: Disabled
Ai Tweaker > DRAM Timing Control: these can be set manually. You can go by what CPU-Z shows you inside of the Timings Table on the SPD tab.
Ai Tweaker\ CPU Power Management > CPU Ratio: Auto
Ai Tweaker\ CPU Power Management > Enhanced Intel SpeedStep Technology: Enabled
Ai Tweaker\ CPU Power Management > Turbo Mode: Enabled
Ai Tweaker\ CPU Power Management > everything else on Auto
Ai Tweaker > Load-Line Calibration: Ultra High (this should provide the smallest amount of vDroop without resulting in any vRise)
Ai Tweaker > VRM Frequency: Auto
Ai Tweaker > VRM Spread Spectrum: Disabled
Ai Tweaker > Phase Control: Extreme
Ai Tweaker > Duty Control: Extreme
Ai Tweaker > CPU Current Capability: 100%
Ai Tweaker > iGPU Load-Line Calibration: Auto
Ai Tweaker > iGPU Current Capability: 100%
Ai Tweaker > CPU Voltage: Offset Mode (this enables the voltage to adjust dynamically based on load which is a very good thing)
Ai Tweaker > Offset Mode Sign: +
Ai Tweaker > CPU Offset Voltage: 0.005
Ai Tweaker > iGPU Offset Mode Sign: +
Ai Tweaker > iGPU Offset Voltage: Auto
Ai Tweaker > DRAM Voltage: 1.50V
Ai Tweaker > VCCIO Voltage: Auto
Ai Tweaker > CPU PLL Voltage: Auto
Ai Tweaker > PCH Voltage: Auto
Ai Tweaker > DRAM DATA REF Voltage on CHA: Auto
Ai Tweaker > DRAM CTRL REF Voltage on CHA: Auto
Ai Tweaker > DRAM DATA REF Voltage on CHB: Auto
Ai Tweaker > DRAM CTRL REF Voltage on CHB: Auto
Ai Tweaker > CPU Spread Spectrum: Disabled (the Z68 chipset boards result in a BCLK of 99 MHz in CPU-Z with CPU Spread Spectrum enabled)
Advanced\ CPU Configuration > CPU Ratio: Auto
Advanced\ CPU Configuration > Intel Adaptive Thermal Monitor: Enabled
Advanced\ CPU Configuration > Hyper-threading: Disabled, unless you're 100% certain that you need it. Disabling it helps allow for a higher overclock, it reduces temperatures, and it results in the CPU needing a lower core voltage
Advanced\ CPU Configuration > Active Processor Cores: All
Advanced\ CPU Configuration > Limit CPUID Maximum: Disabled
Advanced\ CPU Configuration > Execute Disable Bit: Enabled
Advanced\ CPU Configuration > Intel Virtualization Technology: Disabled
Advanced\ CPU Configuration > Enhanced Intel SpeedStep Technology: Enabled
Advanced\ CPU Configuration > Turbo Mode: Enabled
Advanced\ CPU Configuration > CPU C1E: Enabled
Advanced\ CPU Configuration > CPU C3 Report: Disabled
Advanced\ CPU Configuration > CPU C6 Report: Disabled
I don't even know if it changes the voltages looking at it. It's just a guide I was given.
Any advice you can hand me?
I am currently reading through http://www.tomshardware.co.uk/forum/265056-29-2600k-2500k-overclocking-guide and http://www.overclock.net/t/1279729/intel-i7-2600k-3-4ghz-asus-p8z68-v-pro-overclock-help
Thanks!
Thanks!
