Hello
I will soon be building a new computer which will have the Intel 2600k CPU. I've figured out most of the components that's I will be using except the CPU cooler, I'm definitely looking for a performance cooler as I would like to overclock to 4.6Ghz (which I have read isnt too hard) maybe 4.8Ghz if I can keep the temperature down.
I've been looking around the forum and there's a few coolers which seem to stick out, The Noctua NH-D14, Thermalright Silver Arrow and a few of the Corsair Hydro series. Ive had a look at a lot of reviews and they all seem very good apart from a few things. The NH-D14 and silver arrow look very big and the fans on the Noctua look awful even though they have great reviews, and the Corsair apparently are very noisy.
As this is my first proper build I'm trying to get it too look nice aswell as perform well, I have compromised on looks for the case as I've gone for the HAF X for the good airflow.
Anyway I did see the Venomous X Black Edition which I think looks great as im going for a black/blue design, also what fans would you suggest in push pull? Im wondering If anyone has this or if anyone knows its good, or if I should just stick with one of the more familiar ones. My room temperature is around 27/28 degrees normally (dunno if this is of any use when picking a cooler)
Thanks
Steve
Thanks
Steve
