27" 4k OLED recommendation
10 May 2004
Middlesex
Hey guys,
I'm looking to swap out my IPS for an OLED. It's used 80% for gaming (on PC), 20% for productivity (on MAC).
I play Valorant, CS2, WOW and the odd AAA. I can't go bigger than 27" due to space.
Google suggest that this is one of the best:
I'm not too worried about burn in as I set my monitor to turn off after 2 minutes of inactivity but when on my MAC the screen is always fairly static.
Are there any other's you'd recommend for around the same price (or less)?
Also, do you know if the above comes with a VESA adapter, there seems to be mixed reports.
Thanks!
2min 45 seconds of this videos says it comes with an adapter with Asus logo on. 100mm x 100mm vesa which he attached to a arm.
Snip
Great, thanks!
Thanks, is there any reason you prefer the MSI monitors?
