If you're simply after 27" for gaming I wouldn't recommended the HZ27WC myself tbh. Perhaps he even intended to use it for console gaming which instantly renders the HZ27WC useless.
A lot of gamers want to run things at 60FPS at the highest available settings as well, the GTX580 is a great videocard but even it will struggle running everything at the best settings using the native 2560x1440 resolution. Last but not least, I wouldn't call over 400 pounds (even with the current weekly deal) "a bit" over his budget![]()
I bought mine at £379 which is £129 over his £250 budget, maybe sounds a lot in % terms but fr what you get it's very cheap. They are always going on special even below what I paid so wait for one of those. I still stand by my suggestion but choice is his
I can go to £300 at a push and it will be for gaming and surfing the net and will be normal desktop use.
For £300 this is what you want...job done!!!
http://www.overclockers.co.uk/showproduct.php?prodid=MO-052-DE&groupid=17&catid=510&subcat=
Will be just for BF3 tbh that`s all i play at the moment,got 2 in mind the 27" iiyama E2773HDS or the Asus VG236HE 23.
28" 16:10 TN is absolutely horrible since the vertical viewing angle will kill your experience totally!
Also, games today are programmed for 16:9.
