27" LED IPS Monitor.
Permabanned
19 Jul 2012
Buckinghamshire
I'm having a hard time finding a good, but cheap IPS 27" LED?
Can someone point me to a good few monitors. I saw a LG IPS277L-BN don't know how good it is though?
Edit just found out the LG doesn't have DVI-D. just d-sub and hdmi:(
Seeing as it looks like you may be able to get the LG for less than £220 it may be worth a punt, you could always DSR it if it's carp. It depends on your expectations for a budget IPS monitor, I'm guessing you looked for reviews and info. on the web already. If you do get it I would be interested to know what you think of it, I'm not looking to upgrade at the moment but I if/when I do I will be looking at budget 27" IPS monitors myself.
Seeing as it looks like you may be able to get the LG for less than £220 it may be worth a punt, you could always DSR it if it's carp. It depends on your expectations for a budget IPS monitor, I'm guessing you looked for reviews and info. on the web already. If you do get it I would be interested to know what you think of it myself.
I would get the LG, but it doesn't do DVI-D only HDMI and d-sub which I don't use either.
