Hi Guys,
I hope you can help as I am finding it difficult to decide on which 27" monitor to purchase.
My budget is around £200 and the main purpose for the monitor will be gaming.
I currently have an old 24" Samsung T240HD and my GFX card is an older Radeon R9 280.
I am ideally looking for a 75hz monitor with freesync. Even though I cannot use freesync with the R9 280 I feel the 75hz would be a slight benefit over a 60hz monitor and would also give me the option of freesync should I upgrade in the future.
I am also not sure whether to keep it simple and stick to a 1080 monitor or take a step up to QHD.
My main concern with going QHD would be a potential FPS drop in games as the R9 280 is rather old now.
I am guessing that with a £200 budget that a TN panel may give the best bang for buck?
My short list currently is:
Acer Nitro VG270
AOC 27V2Q (lovely looking frame less monitor but not sure if its a bit trashy for gaming?)
Iiyama G-Master G2730HSU-B1
Thank you in advance for any help or insight that you can provide
Acer Nitro VG270
