27" Monitors?
5 Mar 2007
Macclesfield
Hello,
I’m thinking of upgrading my 20.1 Belinea for a bigger monitor. I had talked myself into a Dell Ultrasharp 2407WFP 24". However, last weekend i viewed two similar monitors next to each other and this size difference was not that much, I’m now slowly convincing myself (and more importantly the misses) that a 24” is not big enough...what are the opinions on the larger monitors? I’m thinking specifically about the Dell Ultrasharp 2707WFP 27"? As its such an expensive item I’d like to get a few opinions before I part with the cash. It will be used for browsing gaming and the odd film.
(Used with a 8800 GTS 640)
Cheers
I'd go for the 2407WFP-HC better value best panel the 2707WFP I don't think is worth the premium especially as it's the same resolution (large dot pitch)
