27"ProLite E2773HDS x 2 portrait ? help
1 Nov 2011
:confused:
hi all this is my first post here "Editor waves hello to monitor"]
and i truely need some help
i am running a i7 2600k oc 4.8Ghz
i have 8gb ram @ 1.35 v
Asus 560 ti x2 sli @ x8 per rail
1000w Psu
win7 ultimate
but now i need to get 3 monitors but space is abit of a issue this is what i want to do
Buy one
Iiyama ProLite E2773HDS 27" Widescreen LED 1MS Monitor - - - Landscape mode
buy two.
???????? ??????? ????? LED - - - Portrait mode
i cant afford the 30" monitor and 2x 22"
so i want a 27" monitors and 2x ??something?? that will look like this
What are you using them for? portrait monitors generally look a bit gash unless you have a practical reason to use them in portait mode.
so i will need two monitors and there sizes that can go in portrait mode and have a swival base
wow this is more difficult than i expected i know what i want but dont know the products i need
I do know one thing the Landscape monitors/middle monitor has to be 27" and under 270 quid with height ajustment
thank you for helping
as you can see in this utube vid he has managed to match all 3 monitors in height
i know this is a 30" setup
i would like a 27" setup that looks like this link
ok we seemed to of drifted off the main point :)
[monitor 1. unknown in portrait] + [monitor 2. 27inch Landscape] + [monitor 3. unknown in portrait]
could really do with some help in matching these monitors up please
ok so monitor 1 and 3 must be on Swivel bases
once in portrait mode they have to match up with the height of the 27" monitor
giving the illusion of on long monitor
i dont know which monitors to get so please could you tell me which 2 monitors i need to buy to add to a Iiyama ProLite E2773HDS 27" Widescreen LED 1MS Monitor
ty
The setup in the video is using Eyefinity (AMD) with a workaround to use 3 monitors with different resolutions.
Nvidia Surround requires 3 monitors with matching resolutions. I've not seen a workaround for this.
Without a workaround the setup you propose won't work with Nvidia Surround.
i didnt know that thank you so much , you have saved me from a costly mistake
wow i didnt even consider if Nvidia would work with mixed monitors
Surveyor your a real gent thank you .
