Im looking to replace my Samsung S27A950 or SA950 as it is also known by. For 2D performancce im more than satisfied but it really do a horrible job when it comes to 3D. Ive tried TriDef on my 7950 and 3d vision through DVI spoofing and on a 560 ti sli setup. The Crosstalk is sooooo bad its a joke. Even using the build in 2D to 3D conversion it has horrible crosstalk.
Ive posted another thread a while back asking if better glasses would solved my problem (they cost around 150 dollars or 900 Danish Krones) but no one apparently knew anything about it.
So what im looking for is THEE best 3D monitor on the market offering the least amount of crosstalk. It doesnt matter what kind of software it uses as long as it is 120hz and uses frame sequential(but if it ALSO supports other sort of 3d modes like the SA950 does thats fine) and is 27 inch.
Thanks in advance
Thanks in advance
Heavy Crosstalk on the Right Eye, if you switch L/R through software and monitor it goes over and becomes heavy crosstalk on the left eye, suggesting its somehow the monitor, atleast to me.
Ive tried all the so called fixes out there that doesnt help such as:
1) Different Response time(normal, fast, fastest)
2) Different view angel settings
3) Different display ports(even hdmi even though it caps the fps )
4) Ive tried different rendering methods (side-by-side, frame sequential, Top-to-bottom)
5) Tried Balancing out fore/background which sometimes helped alittle but also almost killed the 3d depth effect.
6) Ive tried AMD HD3D, or Direct3d Stereo in tridef screen setup
7) Even the monitors OWN 2d to 3d conversion does the heavy crosstalk
Skyrim was mostly bad when you had a bright background where your weapons would look like you have been drinking and saw 3 of them if.
Torchlight 2 is mostly bad on the main character you control, look like someone put a transparent picture over and slided it to the left.
Battlefield 3 had it to, was shown on whatever weapon i was aiming with and on items with a bright background.
Links:
TriDef Simple crosstalk test
My previous attempt to get help
Review with pictures showing the crosstalk issue
