- 28 Nov 2011
Hi guys
I'm new to overclocking and have a few questions regarding safe temps/voltage. Every place I look has different values for safe temperatures and voltage. For the 2700k, Overclockers suggest no more than 1.425v and max temps below 70c.
Am I right in thinking that voltage is pretty much irrelevant, as long as you stay within safe temps; but higher voltage = higher temps? For example, if a 2700k processor was in an air cooled system and 1.4v took the max temp at load over 70c, then that would be bad, but if you put the same chip in a liquid cooled system, with the same voltage, and the max temp at load was only 60, then that would be ok?
I have a 2700k, liquid cooled, in a Asus Maximus Gene-Z mobo.
I can overclock to 4.8GHz without crashing at max load in IntlelBurnTest on max with 8 threads. CPU voltage is at 1.39 and max temps hitting between 60c and 69c. If i lower the CPU voltage I get BSOD in IBT.
I can't overclock to 4.9 without exceeding safe temps, temps get up to 70c - 75c.
Seeing what some people are acheiving with 2700k's on air cooled systems at safe temps & voltage (4.8GHz+), does this mean that I've just got a less than average chip considering my liquid cooling?
Thanks!
Thanks!
