- 4 Dec 2008
Hi guys,
I'm having problem with OCing my CPU.
Don't get me wrong, I can overclock it a bit up to 4.8 GHz but after 2h of Prime95 crashing.
My settings:
Vcore - ofset +0.005v (1.376v)
Advanced Turbo disable
PLL enabled
Intel Speed step tech enabled
Turbo Boost:
-short duration 220
-long duration 180
Additional Turbo voltage - auto
Speed spectrum disabled
LLC level 2
DRAM volt auto
PLL Voltage 1.709v
C1E - enabled
C3 disabled
C6 disabled
Package C states disabled
What I'm doing wrong?
Temps are 60/71/67/62
My settings:
PLL enabled
Turbo Boost:
-short duration 220
-long duration 180
LLC level 2
DRAM volt auto
PLL Voltage 1.709v
C1E - enabled
C3 disabled
C6 disabled
