2700x and this?
22 Oct 2008
Lisburn
https://www.overclockers.co.uk/g.sk...hannel-kit-f4-3600c17d-16gtzkw-my-101-gs.html
Is this ram ok for a Ryzen 2700x setup? Looking to plug into a Strix x470 mobo.
https://www.overclockers.co.uk/asus...ocket-am4-ddr4-atx-motherboard-mb-6c1-as.html
If it's not the best option (I need 16gig) then what's a good alternative? will 3600 RAM work on the new x470 mobo's using XMP? Or will there be a bit of fiddling required?
Also do the matured BIOS's make plugging in higher than 3200 RAM, easier or is there still a limit to the memory speeds that Ryzen can play with nicely without too much faffing about?
Post operation meds making me a bit fuzzy and I've a build to price up for a customer, so need a few questions answered. Cheers.
Doubt it will run rated speed 100% stable from what I've seen. 3200 c14 is more realistic. If the price is good it's wise to buy faster ram though, just have to be prepared to enter in manual settings.
The 8 Pack RAM is better and guaranteed Samsung B Die:
Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-25600C14 3200MHz Dual Channel Kit - Black/ @ £199.99 inc VAT https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
TDPGD416G3200HC14ADC01, 3200MHz RAM Speed, CAS 14-14-14-31 Timings, 1.20-1.40v VDIMM, Lifetime Warranty with OcUK.
Only £199.99 inc VAT.
ORDER NOW
Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-28800C16 3600MHz Dual Channel Kit - Black/ @ £209.99 inc VAT https://www.overclockers.co.uk/team...3600mhz-dual-channel-kit-black-my-08q-tg.html
TDPGD416G3600HC16ADC01, 3600MHz RAM Speed, CAS 16-16-16-36 Timings, 1.20-1.40v VDIMM, Lifetime Warranty with OcUK.
Only £209.99 inc VAT.
ORDER NOW
Team Group Dark Pro "8Pack Edition" 16GB (2x8GB) DDR4 PC4-30900C18 3866MHz Dual Channel Kit - Black/Grey @ £209.99 inc VAT https://www.overclockers.co.uk/team...3866mhz-dual-channel-kit-black-my-08r-tg.html
TDPGD416G3866HC18GDC01, 3866MHz RAM Speed, CAS 18-19-19-39 Timings, 1.20-1.40v VDIMM, Lifetime Warranty with OcUK.
ORDER NOW
Aye grab the latest one at 3866 and give it a try first to see if it works.
My Ripjaws V worked fine at 3600C16 with the CH6 and 1800X
