- 18 May 2010
- London
When you load the stilts safe settings, your ram voltage and ram boot voltage will be set to 1.4v don't change it. Same here as well, CPU and SOC LLC set to 3. It was the same with the 1700 as well.
I don't have a CH6 board. So will be doing this manually on my Prime Pro X370.
So 1.4v on the ram and boot voltage.
SOC auto.
Sounds easy.
I'll update when my pc starts crashing.
Edit:
Do I need all the secondary timings too or will 3333MHz 14-14-14-30-52 suffice and leave the rest on auto?
Link.
Is the Fast 3333MHz tougher to achieve?
