270X advice
As the MSI was bought from OcUK, you're allowed to remove the cooler while keeping the warranty (provided nothing is damaged & the cooler can be replaced) even though there are stickers in place. However, if dust and airflow aren't causing the problem then get the card RMAed rather than mess about as the card should last longer than it has without issues unless mistreated.
