280X question :)
11 Jun 2013
You'll be fine. You've got a DVI and a HDMI which will be fine but you will need a hdmi to a dvi adapter (should come with the card) as the monitors only have a 1x Analogue and 1x DVI-d.
From my experience, most card manufacturers only come with DVI > VGA adapters with the exception of MSI and Sapphire. Those two tend to at least give one, or two DP adapters.
Problem.
This 280X card is listed as having:
- Display Outputs: 2x DVI + 1x DP + 1x HDMI
Now: If you goto this utube video and goto 5mins 45secs you will see it clearly has 1xDVI, 1xHDMI and 2x mini display ports ?
Not the usual service from overclockers. Copy and paste springs to mind :(
Problem.
Problem.
http://www.youtube.com/watch?v=hZQANNndqOA
That'll enable to connect both up (didn't know about the HDMI to DVI! Thanks RJC :D)
No probs, saved me many a time :D
Problem.
Problem.
I will bring this to the attention of the shop staff.
Problem.
It's as per the images, we get specs from AMD, then images later. Seems Gigabyte and HIS changed the outputs, shall get descriptions updated tomorrow to match images which are correct.
