Since the debacle of waterblock on my Sapphire 280x Vapor-X, have re-fitted the stock cooler this morning, yet am now seeing some very crazy temperature readings.
When I was running this last week, was getting approx 50-55 degrees with fan on 100%.
Now when I start anything up that puts the card under load, temps jump straight up to 100 degrees
Have had the cooler off and checked TIM layer and that all looks good. Even touching the back of the card it does not feel like it should be hot enough to boil water.
Sat at idle / desktop work have temp of 38 degrees with fan at 21%.
Any ideas as to what is going on here? Borked temp sensor? Have some more / new thermal pads coming at some point next week (when OcUK get some in...) so will be re-seating then too
