Hey all, fitted the brakes to 1side today but up on testing it seemed to be binding? The calipers went to the garage to all be freed up etc, but it looks like the pads are constantly touching, is there anything I should check? Thanks.
AmDaMan said:I don't think so, we are gona double check it tomorrow. One thing I thought was strange though, you know the area where the pads touch the disk? Well it looks like it's touching the outside of the disk too? Is it meant to go that far out?
What was the condition of them, the disk may have rusted up through the pad not making full contact which it now is hence all that grinding
Ouch! That looks pretty messy! I'd remove that disc and check it for signs of cracking if you drove it any distance (cant hurt to check).
I dont know a lot about the setup and new stuff but can the caliper be remounted or moved if the mounting botls are loosened?
My only concern no is I have run out of bolts for the other side and no one seems to have them! M12x 1.25mm. I'll search about tomorrow again. Also one of the slider pin rubbers looks abit worse for wear, is there anyone that sells universal ones? I don't want crap to get in it. Also no comments about the state of my car I know, i know!
