- 18 May 2010
- London
The so-called target time frame is the fourth quarter of 2011, although the inherent complexity and massive transistor number (compared to existing GPUs) may or may not end up in delays.
I have a feeling that this might come true and 28nm cards from both AMD and Nvidia wont be seen until Q1 2012 at the earliest.
Entirely possible...
First there is the question of the fabs, and their ability to get large 28nm designs out effectively. AMD have access to both Global Foundries and TSMC, whereas Nvidia will be using TSMC exclusively, so if delays at TSMC become an issue then Nvidia could have more problems getting a high-end GPU out than AMD. That said, smaller 28nm designs should be appearing earlier in the year, so it should give the fabs a little time to refine the process before the more delicate large-GPU designs come through in Q4.
