2900 gt overclocking
Permabanned
15 Aug 2006
Gainsborough, Lincs, UK
overclocking a 2900gt (ocuk deal atm) using the AMD GPU clock tool to edit clocks and ati-tool to stress and scan for artifracts....
i hav foudn my top clock before getting errors 712/1818, i went to run 3dmark06...
had gpu-z open on my other screen (dual screen) and it lowers the clock down to 600 by itself :-S???
can anyone help me to stop it doing this?
Matt.
yep...
i click run 3dmark at 708/909 clocks then it flashes onto loading screen for first test to stock clocks 600/800... then wen i esc the test it goes down to 510/510 :-S?
latest drivers.... wtf is goin on?
help!
Have you got an 8-pin PCI-E power connector plugged into it? Apparently it needs that for overdrive to work, you should be able to clock it just using ATI-Tool, and set up profiles/voltages etc
Although it wasn't 100% stable on mine, I was able to get 800/2000 out of it, but I cant remember if that meant upping the gpu voltage or not, or if it was even possible on the 2900GT
