2900pro 512bit Interface Confirmed.....by HIS
28 Oct 2005
Scotland
http://www.techpowerup.com/index.php?39958 Source!
http://www.hisdigital.com/html/product_ov.php?id=341&view=yes
Check it out guys, on the HIS product page they have announced their 2900pro 512mb and oh my does it look like it could be quite a steal! ;)
Unleash the Gaming Power of DirectX® 10
The HIS Radeon™ HD 2900Pro unleashes the power of DirectX® 10 with awesome performance, stunning visual effects and more dynamic interactivity than ever before. Surpass reality with easy CrossFire™ scalability, built-in HDMI and 5.1 surround audio for an immersive HD Gaming experience. HIS Radeon™ HD 2900Pro delivers ultimate realism and performance at all resolutions in high dynamic range from a 2nd generation unified shader engine.
Ultimate High Definition Gaming Technology
The HIS Radeon™ HD 2900 powers today’s titles and introduces a new platform for upcoming DirectX® 10 games. Our next-generation unified shader engine with 320 unified stream processors, a 512-bit memory interface, CrossFire™, game physics, and built-in HDMI with multi-channel 5.1 surround audio establishes a new level of performance and technology designed for discerning gamers.
HIS Radeon™ HD 2900Pro delivers ultimate realism and performance at all resolutions in high dynamic range from a 2nd generation unified shader engine and easy CrossFire upgradeability. Built-in with HDMI audio and video, HIS Radeon™ HD 2900Pro enables a one-plug big-screen HD gaming experience with ATI Avivo™ HD video & display technology with advanced high definition features.
Leadership for Windows Vista™
The HIS Radeon™ HD 2900Pro delivers powerful graphics performance, improved stability, and an immersive HD gaming experience for Windows Vista™. ATI Catalyst™ software is designed for quick setup of graphics, video, and multiple displays, and automatically configures optimal system settings for lifelike DirectX® 10 gaming and the visually stunning Windows Aero™ user interface.
Superscalar unified shader architecture
320 stream processing units
512-bit 8-channel memory interface
Comprehensive DirectX® 10 support
Integrated CrossFire™
High-speed 128-bit HDR (High Dynamic Range) rendering
Up to 24x Custom Filter Anti-Aliasing
ATI Avivo™ HD video and display technology
Built-in HDMI and 5.1 surround audio
Dynamic geometry acceleration
Game physics processing capability
So there we have it a nicely cut down 2900XT and at the price of around £170 it could be a great value bit of kit :) And yes I will be getting one of these!
Wow...its just a downclocked 2900xt :/ which can easily be clocked to 2900xt speeds but probably not that much higher...still its an absolute steal.
I think even a 256-bit interface wont be a problem either, wont limit too badly if it ended up like that! But I read 512-bit and though....excellent! I was looking for an hd2900xt on the cheap but I think this is the road im heading on now!
You say it can be clocked to xt speeds but what if it only has one PCIE power connector, limiting any decent overclocks.
Do you not think that may be just enought to take it close to XT levels mate ;) I think managing to clock it close to an XT at stock would be very interesting!
Just realised that OCUK have got the specs spot on from the off with these cards ;) same clocks etc! Just want to know if 30th September is confirmed! :D
Well considering an XT wont function properly unless it has two PCIE cables connected and this is at stock speeds, no i don't think it would be enough. Then again they may have not even messed with the original XT design and just the clocks have changed in which case its an unbelievable bargain.
It won't just have one power connector no chance. As it is just a very slightly downclocked XT that won't knock the fact it's still going to require a ton of power which it can only get from two PCI-E pwr connections. It's most likely going to be a 8/6 Pin job just like the XT.
Least I know you had your XT working with a Hiper Type R 580w tom :P gonna be doing the same with the pro! Your right about the black box though, complete steal!
Well i guess these should work with an XT in XFIRE, i think i might pick one up in time for crysis and pray it supports XFIRE from release.
Yep they should do. Id guess the XT would just clock down to pro speeds though. Whilst in XFIRE mode. The GTS 320MB is ****ed :D
Probaiblly will be the two power connectors.
Tom what did you manage to clock you XT up to?
