2900XT & Cursor graphics curruption
19 Oct 2002
Torbay, Devon, UK
As title
Is anyone else getting this still. Its like a black fuzzy box.
I have done a screen print and it is not shown in it. So is it the card or the monitors, as it happens on both my Dell 2407 and VX 912. I have only ever seen it in windows and never in any games.
the_champ_101 said:
Ah! More trouble for the X2900XT, poor AMD lol. The solution would be to somehow swap it for a 8800 series, all problems fixed. :D
How very constructive. Well Done.
Are the people getting the corruption changing their cursors?
What resolution, depth setting and refresh rate are said people using?
Are said people installing on top of previous drivers or doing an uninstall-reinstall?
Im using Vista 64bit and have not changed the cursor.
Running 2 19" crt's, both at 1280x1024 with 85hz refresh and 32bit colours.
To update drivers, I use ati uninstall, then uninstall the driver using device manager, then reboot and run driver cleaner, then reboot and install new drivers !
Uninstall Driver cleaner.
I cant upload a pic, unless I use a camera. As a screen print, does not show the problem.
Thats why its so strange.
