2900XT problem
21 Jul 2006
South Wales
Getting a weird problem with a new 2900XT 512mb silent heatpipe
I've tried reseating...
current spec of the kit is:
ASUS A8N-SLi Deluxe s939
AMD Athlon64 4800 x2
1gb ballistix pc4000 500mhz
580Watt modular hiper
1 long beep 3 short beeps
there are 2 power connectors, only connected the 6 prong ... dunno if im supposed to connect the otherone as well.....
will try with a different power connector
any ideas peeps?
ok update: tried old gfx card and it posts fine
but the new card back in and it still beeps
updated my post....
searched award bios beeps
One Long and Three Short Beeps. Video (EGA) Display Circuitry.
thts what i found...
so is it the power? or the gfx card?
Specification Description HPU-4R580
Wattage Rated Wattage 580 Watts
Peak Load 630 Watts
Switch Type Manual Rocker
Auto Standby ATX Logic
Fan 120 mm - R.P.M. 700 ~ 1500 R.P.M.
120 mm - Type Sleeve Bearing
Fan 80 mm - R.P.M. 1250 ~ 2400 R.P.M.
80 mm - Type Sleeve Bearing
Cable Thickness 18 guage
ATX Main Power Connector 24 pin (20 + 4pin) 1
Omnigrid™ Connectors 2 pin - P4 4 pin connector, 450 mm 1
3 pin - PCI-E 6 pin connector, 450 mm 1
4 pin - Molex 4 pin connector, 450 mm 1
4 pin - Molex 4 pin EZ-Grip connector, 650 mm 1
4 pin - Molex 4 pin EZ-Grip connector, 350 mm 1
4 pin - Molex 4 pin EZ-Grip connector, 250 mm 1
eXtender™ Connector Molex 4 pin to two SATA connector 2
Molex 4 pin to floppy connector 1
Molex 4 pin to Molex 4 pin EZ-Grip connector 4
Two Molex 4 pin to PCI-E 6 pin connector 1
Input Parameter Voltage Range 195 ~ 240 V
Current 6A
Voltage Range (for US model) 100-120 V
Current (for US model) 10A
Frequency Range 47-63 Hz
Output Parameter +5V 2.0A - 36A
+12V 1 1.0A - 20A
+12V 2 1.0A - 18A
-12V 0A - 0.8A
+5VSB 0 - 2.5A
+3.3V 0.5 - 30A
Output Load Regulation +12V 1 & +12V 2 < 360 W
+3.3V & +5V < 280 W
+3.3V, +5V & +12V < 560 W
Output Voltage Protection +3.3V < 4.5V
+5V < 6.8V
+12V < 15.6V
Power Good Signal Rise Time < 20 ms
Signal On 100 - 500 ms
Signal Off < 1 ms
Power Hold 16 ms min
PFC Power Factor Correction Active (N/A for US model)
Chassis Thickness 1.0 mm
Unit Size Dimension 158 x 150 x 86 mm
6.2" x 5.9" x 3.4"
Weight Net Weight 2.45 Kg
got a feeling its not the power but the fact the gfx card isnt all the wya in due to fact the chipset is right under it...
new computer needed me thinks lol
time for a massive upgrade....its been 2 years :)
Your meant to also plug in 2 connectors. basically a minimum of 2x 6 pin connetors (the 6 pin fit into the 8 pin sockets). The 8 pin are apparently only used for 'official' overclocking with catalyst.
Matthew
Yeah, you need two connectors on there. Starting with the end of the card, you plug in a 6pin cable, then you leave two pins free on the next connector then connect another 6pin, if that makes sense.
::::::: -> end of the card
This terrible diagram is meant to show what I mean.
