290X CF and/or 295X2
6 Mar 2010
Thinking of upgrading my 7970s to either 290X CF or 295X2 (currently erring towards 290x CG as i can completely disable the 2nd GPU if needed), but will be looking to watercool them on my custom loop.
Are any of the ones on offer at the moment standard layouts so i can add waterblocks, as I cant work out whether its a custom PCB or just the cooler on most of them?
Assuming clock speeds are identical 8GB versions will be slightly slower than 4GB counterparts, however you won't notice a difference. Should you bench any game that uses more than 4GB of video memory, then difference between the cards will be instantly noticeable. Only go 8GB if you're planning to use more than one card and game at 4K or higher.
hmmm looking at the graphs.. doesnt seem worth paying £70 over a 4GB model just for 2-4 fps but I guess they arent vram heavy games. Still I dont think the 8GB models are worth.
Tri X cards all have hynix ram, whereas with reference cards it's random whether or not you get elpida or hynix.
Hynix is generally better and will overclock further.
Actually i believe the Sapphire 8GB Tri-X cards have Elpida memory. If you want Hynix 8GB you'll need a Sapphire Vapor-X.
Seems like 4GB will be enough, even though I am looking to CF?
I take it the Asus cards that are on special arent reference then? The 4GB Sapphire card is the same price as the 8GB one.
Going by the monitor in your sig you will be fine at 1440p.
It's only really 4k that will eat more than 4gb and even that is rare.
