290X Matrix Platinum Overclocking ?
19 Feb 2007
Sol
Hi Pack, got the Matrix this morning and loving it so far, What would a safe voltage be to run 24/7, I've heard it ranges from 1.20v to 1.30v but really not sure.
Any information is appreciated :)
They overvolt under load like any 780Ti so what you set in software is not actual. Use DMM and test as you scale up.
I found normally on air around stock volts is the best option for 24/7. On water you have much more to play with.
Its true man!! I tested with volt meter. Best volts was almost stock. You give em too much they peal really high on load.
