290X Number Of PCI-E Lanes ?
19 Feb 2007
Northampton
Anyone by chance know how many PCI-E lanes the 290X uses ? As in the number of lanes a CPU has etc...Just curious as to how this works :)
On the CPU you have (Devils Canyon) you have 16 CPU lanes.
With one device plugged it, it'll get the full 16 lanes.
Anymore than that and it'll have to share lanes. Presumably 8/8
A Haswell-E 5820 CPU has 28 lanes and the Haswell-E 5930k and 5860x have 40 CPU lanes, so are considered better for people with 3x GPU's or more.
Could be wrong but I'm pretty sure a GPU would use however many lanes you gave it. Although strangely it wouldn't make a difference past a certain point.
What it boils down to is bandwidth.
1x PCI-E 2.x lane = 500 MB/s
1x PCI-E 3.0 lane = 985 MB/s
4790K has a total of 16 PCI-E 3.0 lanes.
8x PCI-E 3.0 lanes is roughly equivalent to 16x PCI-E 2.x lanes.
Those PLX switches that shankly1985 mentioned just kind of emulate extra lanes, the connection between the PLX chip and CPU is still the same bandwidth.
I have had mine running in the PCIe2 8x, there is about a 3 to 5% performance drop compared with 16x
Yeah, just ignore that. You have to use it's rendering test tool thing before it'll tell you what it's actually running as.
Yeah that's what I do lol but it still says am running pci 3.0
Strictly speaking they don't, they have more. The cpu has a direct 16x pci-e 3 connection but the cpu also has a high bandwidth connection to the southbridge chip which also has up to 8 pci-e 2.0 x1 slots with more bandwidth available.
I presume on a PLX based board where as the pci-e 3 on the chipset is usually connected directly to the slots and NOT through a chip, the PLX chip is connected to the pci-e slots, then the plx chip is connected both through the normal 16x direct to cpu connection AND using some of that bandwidth through the chipset, doing some fancy balancing of load stuff I would presume.
SO there is say 16GB/s of bandwidth direct to the CPU and 5GB/s through the chipset, with the PLX chip you can connect these together before going to the pci-e slots.
EDIT:- DMI 2.0 seems to be a 20Gbit/s speed, so about 2.5GB/s of which you'd say the majority actually during a game/benchmark(after it's loaded and hd access is minimal) would be available, so a 15% or so increase over the solo 16x slot.
EDIT2:- more reading, the plx chip also creates lots of extra pci-e lanes because a decent amount of traffic is just from one gpu to the other, not back to the CPU. So by adding extra lanes the gpu's can talk to each other without eating up the bandwidth available from the cpu. I could see both methods improving performance tbh. Why Intel doesn't have a "gaming" chipset which adds this to a southbridge naturally I really don't know.
I've not been able to find any diagrams showing it coupled to the DMI 2.0 link? I would think they'd want to separate Southbridge functions (SATA) from GPU traffic particularly as the PLX switches have been found to cause latency which can be a killer with sound cards etc.
That was something I was reading up about before picking this board and was a gamble on my half.
So far I have used two sound cards, crossfire, single gpu and I have noticed no latency at all.
I also believe the plx is much improved upon since its launch.
