So almost two years ago I decided to buy a 290x and after a bit of research I ended up getting the MSI 290x 4G. It's a hot card and with the reference 290x hitting 290x up to 95c, I wasn't very pleased that my after-market card was getting similar temps. But then again I've been using 2 * 2560x1440 screens so put the temperatures down to that. Not every card is the same as well and I thought I was just a bit unlucky.
Fast forward to now, temperatures were getting worse and my card was starting to throttle itself quite badly. I thought it was maybe coming to the end of it's life which is quite early for a card to fail. Before I sent it in for an RMA, I decided to see if I'd get any luck out of re-applying thermal compound to the GPU.
That's when I saw this.
http://imgur.com/a/8pUxS
After fixing it all up and putting it back together, surprise surprise, my temperatures drop significantly and I'm now comfortably overclocking the card.
Not cool MSI...
Not cool MSI...
