- 21 May 2015
Hello all, I'm looking for a bit of advise as to whether upgrading to an 290x (or a 970) would be worth it for an oldish system or whether I'd be better off plumping for something cheaper such as the 960s?
I've been looking at either of the 290xs below
http://www.overclockers.co.uk/showproduct.php?prodid=GX-364-AS
http://www.overclockers.co.uk/showproduct.php?prodid=GX-363-AS&groupid=701&catid=56&subcat=1752
(I'll also be needing a new PSU to power these too)
However I've got an older i5 2.6ghz on the old socket LGA 1156 and I'm a bit concerned that I'll end up being bottle necked by the Processor and might be better off saving some pennies and getting a slightly cheaper card.
I'm upgrading from a 5770 so I'm sure whatever I do I'll notice the difference.
Running HWMonitor shows whilst playing Witcher 3 on medium settings at 1680 x 1050 and the load on my GPU is 100% but the load on the CPU is 30% so even though its old the CPU seems to have legs in it.
FRAPs is telling me my average FPS is 22 on Medium settings at on Witcher 3 (with HairFx turned off!) which isn't too shabby for an aging system but far from ideal.
So really my question is if I splash the cash on a 290x would it be worth it or would I find myself with a similar type of performance as if I'd gone for a 960 because of the limitations of the old CPU?
Thanks in advance for your opinions.
