290X upgrade?
23 Sep 2005
Fife
I currently have a
4960K @ stock
8GB RAM
290X Lightning Edition 4GB
I currently play (a lot) of R6:Siege, a bit of TW Warhammer, BF1 and will probably play Battlefront 2.
I play on a 34UM95 ultrawide at 3400x1440.
What would be a good upgrade? If I could get a constant 60fps in R6S I'd be happy.
Which is ~£480 or so? Would a 1070 be of any use? Don't mind spending the extra (especially if it means my room doesn't heat up like it does with the 290X!)
A 1080 will be a fantastic upgrade double vram nearly double the performance ( give or take) much lower power usage and cooler running deffo the 1080
