2d clocks in afterburner?
23 Jul 2009
Bath
I want to set the 2d clocks for my 5770 in afterburner, but it won't let me go below 775 (the min oc in CCC). This is with the unofficial overclocking bit enabled. Got a great 3d profile set at 1GHz, but I don't want it running those clocks all the time! I tried editting the 2d profile .cfg file, but when it tries to apply it it has a blank value for core clock so leaves the clock at the 3d value while reducing volts and memory clocks. Any idea how I can do this? Cheers
I've got the same problem. i was happy to use the Asus voltage tweak program but it did't seem to have the ability to set user defined 2d clocks i.e. 157/300 just like cat 10.4 and previous. I only upgraded to 10.6 due to crashing in L4D2 (which it solved).
