2fa is there a correct way
19 Mar 2011
of setting up 2fa using another authenticator?
basically i want to move away from 1 authenticator and use another 1 is there a certain way i have to do this?
thanks
I wouldn't recommend Authy as they had a security breach earlier this year. They also don't make it easy to migrate to/from other 2FA apps. 2FAS or Ente would be my choices, and they make it easy for you to import/export a backup file if you wish to move to another 2FA app. Bitwarden offers 2FA too but I haven't tested it as I use it for passwords and don't want all my eggs in one basket.
