neologan said:yep only the old Ballistix Micron based stuff could do 2-2-2-5 and strangly enough add all those number together and that's how long in minutes the stuff would run without needing an RMA.
Minstadave said:2-2-2-5 is very rare on 2x1gb kits, I think I've seen the odd set of Ballistix do it, but only one or two.
Its not even worth worrying about though, 2-3-2-5 is very good for a 2gb kit, you're not going to get much better.
Street said:I can only keep CAS2 up to around 230MHz, but I can get 2.5-3-2-5 up to 257MHzWell worth the price IMO.
dillingerdan said:Kingston have a 2GB 2-2-2-5 PC3200 Kit available.
Conman said:Yo steet!
What voltage to put it in and what is your RAM spec ?
Street said:Its Corsair 3500LL RAM that I've got. I only need to run 2.6V through it... It doesn't respond well at all to any extra volts.
Conman said:thanks
I though you had 3200 C2PT. I just wanna see how the 3200 C2PT capable of.
Kunnak on xs had a set that ran better at tighter timings and lower voltage. Infact he just sold them, i believe they did 3-3-2-7 @ 260mhz with just 2.2volts (modded dfi expret bios).ted34 said:There was a thread on xs about these sticks and the lower the voltage the better they seemed to perform. Think he set them at 2.5 or 2.6v in the end. Cant find the link any more though
