2gb compatibility with Nforce2?
27 Nov 2003
Loughborough
Hey all,
I am thinking about putting 2Gb (2x1Gb) in my system to fix the stutter in Bf2, its still a Skt A system though that I more than happy with but have a feeling the ram will have compatibility issues if I don't choose it right.
The system is an Aopen Small Form Factor running an XP2800+ and a 6800 GS OC
Here is the chipset -
* AOpen UK79G-1394 AOpen Form Factor ATX
* Based on NVIDIA nForce2-GT chipset (nForce2 IGCP + MCP-T)
* Supports Socket-A CPU (200/266/333 FSB)
* Supports Dual Channel DDR266 / DDR333 memory (DDR400 available if on-board VGA is disabled)
Which 2Gb kit is most likely to be happy at stock on that set, bear in mind there are no new bios updates these days. :)
Thanks,
Whoop
