27 Aug 2010 at 15:20 #1 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,908 Location N. Ireland is there any chance of OcUK selling just 2gb of ddr3 rams?
27 Aug 2010 at 17:26 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent They do 1 x 4gb http://www.overclockers.co.uk/showproduct.php?prodid=MY-287-CS&groupid=701&catid=8&subcat=1516 I think they did have some a while back Might be worth posting in the product suggestion forum below. http://forums.overclockers.co.uk/forumdisplay.php?f=67
27 Aug 2010 at 17:53 #3 Jony27 Jony27 Soldato OP Joined 15 Aug 2010 Posts 8,908 Location N. Ireland yeah but its like around £80 for the 4gb sorry for posting in the wrong section
27 Aug 2010 at 19:16 #4 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Jony27 said: yeah but its like around £80 for the 4gb sorry for posting in the wrong section Click to expand... Only joking I swear they did do some single kits a while ago for £ 40.00 ~ which were good for budget builds.
27 Aug 2010 at 22:03 #5 Jony27 Jony27 Soldato OP Joined 15 Aug 2010 Posts 8,908 Location N. Ireland i wish they could stock them up again. and how does the MM work?
28 Aug 2010 at 00:04 #6 SeraphX SeraphX Soldato Joined 7 Jun 2010 Posts 7,166 Location Sussex MM is for people with more than 250 posts and 3 months registered, or 100 posts and 1 years registration
28 Aug 2010 at 02:12 #7 Jony27 Jony27 Soldato OP Joined 15 Aug 2010 Posts 8,908 Location N. Ireland damn.. that means i wouldnt be able to use it till december if i was to use it thanks btw
