Yup, Ive Set the McH and all the other settings in the DS3 guide (Except I didnt turn the CPU Vcore up as high becuase frankly, my cpu will go faster without failing any tests on less voltage)
Ive tried DDR voltage up to +0.5 (so about 2.3v) and no matter what, ram doesnt seem to want to go much past 900. Tried running on a 2.5x ram multiplier and lower FSB and CPU clocks aswell to rule out other possibilities for instability.
Havent checked to see how hot its getting (to the touch) yet when running, barely get a chance tbh... system remains 100% stable with the ram at 900 (using 2x multi and 450FSB) with as little as 2.1v in it, but go past about 920 and it just reboots within about 10 seconds of starting up Orthos on a ram test (however itll usually run a CPU test indefinatly)
Havent tried going really loose on the timings yet, stayed at 5-5-5-18, im just surprised how quickly these modules seem to "hit a wall" and go from working 100% stable at lower voltage, to rebooting the PC within 10 seconds of Orthos even with higher voltage, when increased by another 20Mhz =/
I may try going even lower on the FSB and using the 3x ram multiplier just to see if I can get past this, as I reckon the CPU (and quite possibly the motherboard) will go past 450 FSB with ease... Whats the likelyhood of other ram multipliers being implimented in a bios update? perhaps motherboard manurfacturers will start to make them with multi's lower than 2x, as it seems many people are in the same position as me and this would allow people to run E6300's at very high speeds without requiring PC8000 or higher.
I think with my E6300 if I could use a 1.5x Multi (if they could impliment one) I could shoot for over 500 FSB, allowing to keep my ram at 750 or thereabouts, while achieving 3.5gig from the CPU (I honestly do believe this is possible with my 28B E6300, as I have seen 100% stable CPU tests with Vcore showing as just 1.21-1.32.
