2GB Mini SD Memory
12 Oct 2006
Tatooine
Can anyone tell me what they think is the fastest 2GB Mini SD memory available to buy from a known Brand maker. I need the memory for my new Nokia N93 Mobile and I dont want to waste my money on the slow stuff. Any help would be great.
Is the speed really that important in a phone?
I got a regular 2GB mini sd for my xda and it has no problem running tomtom and playing xvid clips etc.
performance isn't that important on a phone, even when the phone is plugged into the PC as a USB drive with a generic cheap noname stick in it I got acceptable transfer rates to and from it.
Its just Ive been checking the net as much as I can and there seems to be a big difference between makes of Mini SD Memory which must have some effect on performance otherwise why the different transfer speeds? If I dont have any luck finding some advice here I think I will just go ahead and buy 2GB of Sandisk Ultra II Memory which I think is the best available, unless someone knows any better or knows of a site that does speed tests on this type of memory for comparision?
