Hi,
I have been running 2gb of OCuk value ram (pc6400) in my pc for a few months now. Everything has been working fine, the system is very stable. I then decided to buy 2gb more of the same ram. The system is now very unstable. When running stability tests the system just locks up and i have to switch off the pc. Sometimes the mobo speaker gives off a slight beep on lock up. I have never had this problem with just 2gb. All the settings are the same in bios for the 4gb as they were with just the 2gb. The mobo is an Asus P5W DH with the latest bios. Im running the ram at its recommended 800Mhz speed. Is it to do with voltage, overheating?
Any suggestions/help would be very much appreciated.
