- 30 Oct 2004
I hava PC with the following spec;
3.2ghz dual core (940) pentium
7800GTX 256mb
1gb DDR2 RAM
320gb SATA HDD
It plays games great, but games such as NFS:MW, Tomb Raider: Legend and Quake 4 (in ultra mode) can be jerky at times. I know these games recommend a 512mb graphics card, but I dont want to upgrade my card so soon (I only got my PC in feb) and will probably get a 512mb DX10 card when theyre available. If I get a RAM upgrade to 2gb will that help with the jerkiness at max settings? What kind of RAM should I get? I know it is supposed to be easy installing RAM but as the only PC maintanence I have ever done before is replacing a DVD drive, do you think it is going to be easy enough, or would you take it to a shop to be on the safe side?
7800GTX 256mb
1gb DDR2 RAM
320gb SATA HDD
