£2k gaming system - spec please :D
£2k budget and want to keep costs down? anyone say contradiction ;)
splitting it over 2 loops will mean the pump has to do less work especially if you are going sli.
I thought this pc was for your friend not you, he doesn't have a tj07 ;)
he doesn't particularly care about case;)
The D5 is a very capable pump andcan easily handle SLI with 2 thick rads. look at rjk's build ;)
2 loops also means I need another pump.
as for £2k, I'm happy to over spend on the important bits, everything else must be cheap. I've already gone £200 over lol
YOUR BASKET
1 x Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail with FREE TrackMania 2 Canyon PC Game £247.99
1 x Xigmatek Elysium Full Tower Windowed Case - Black £149.99
1 x Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard £146.99
1 x OcUK D5 Vario Pump & EK D5 X-Top V2 Value Combo £90.00
1 x Thermochill TA120.3 High Performance Radiator £86.80
1 x Microsoft Windows 7 Bundle - Home Premium 64 Bit £68.40
1 x Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache - OEM (WD5000AAKX) £32.99
1 x EK Supreme HF CPU Waterblock - Nickel Plexi **EN Nickel Plating** £55.79
1 x Samsung SH-B123L/RSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATA-II Optical Drive - Black (Retail) £52.80
1 x Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £47.99
1 x Lamptron FC2 5.25" Bay Fan Controller - Black £24.98
1 x Asus Xonar DG 5.1 PCI Sound Card with built in Headphone Amp - OEM £19.99
1 x Xebec 500mm LED Strip - Blue £12.98
4 x Tygon 7/16" ID [16/11mm] Tubing - Clear (R3603) - 1 metre £7.85 (£31.40)
1 x Mayhems Biocide 5ml £3.70
14 x EK PSC Compression Fitting 7/16 [16/11mm] - G1/4 - Black £2.89 (£40.46)
Total : £1,133.48 (includes shipping : £16.85).
what are the important bits? unless I'm missing something your spec is just over £1k. if you're going with the extreme4 mb add the extra £7 for the gen3.
my bad., thought i'd put the 3rd gen in. I'll update that - thanks.
OcUK basket - £1,100
570 blocks and 420 rad - £300 (direct from EK)
2 570's - £650 (direct from EVGA)
PSU - £180
Total: Roughly £2,100
Important bits are basically the gfx card, CPU and lquid cooling bits. Don't care about the rest as long as it is decent and does the job
£650 for 2 570s? you prob could have for ones already with blocks for that(if they do that for 570s, do for 580) ;)
p.s. hope you checked that the ek blocks fit the evga 570 2.5gb
Lol, I know. I would get a 590 but the EVGA ones are nowhere to be seen so I'll give it a miss.
The 570s have more VRAM though ;)
They don't do previewed blocks with 570's :(
I'll ask OcUK when the 2.5gb 570's are due and decide whether to wait. Will save £50. Stupid phone makes it awkward for me to browse OcUK store :mad:
And yes, ofcourse, I've checked compatibility :D
