2nd gpu out put
7 Dec 2009
i am using 2 monitors on my 5850 crossfire why is it i can only used the dvi input and hdmi input on just one gpu card, if i plug a dvi or hdmi on the 2nd gpu is dont detected it in ati software.should it do this thanks
For more than two cards, you are quite right. However, for just two monitors (like the OP is using) then you don't need to use a displayport output (or eyefinity for that matter), DVI and HDMI will work fine.
Personally I am using a HD 6970 with two DVI-connected monitors right now.
