2nd GPU won't start
11 Oct 2006
Wiltshire
I've got two 8600GTSs in a 965P-DS4 mobo with a DVI-VGA adapter on one output from the second card. Both cards are visible in Device Mangler. I've created shortcuts for the two clients with -gpu 0 and -gpu 1 in them. GPU 0 runs okay, albeit only at 1600 PPD, but GPU 1 says it's not a supported card, try a new driver. This is cobblers as it's using the same driver as GPU 0. Oh, OS is XP32. So what do I need to get the second card working?
Tried that and the driver BSODed. :mad:
I'll get the bits to make a VGA dummy and try again.
Thanks for the suggestion though, it probably is the solution.
<Later> After the reboot the change seems to have taken place and the second card is up and running. :)
Good old "have you tried turning it off and back on again" :)
I have that scrolling across my screen as my screensaver at work.
