2nd Monitor Kicked the Bucket - which of these is best.
27 Jan 2009
United Kingdom
Basically my 2nd Monitor wont turn on :( , just wondering if anyone knew much about them, and which of the below 3 would be the best option.
Any of them are around £120-£130
Would prefer one of the 4K ones as that will match the resolution of my still good monitor.
BenQ EL2870U 28" 4K
Samsung U28R550UQP 28" 4K
I’ve got the BenQ one.
I’ve had it for a few years now. It’s used as a secondary monitor for work stuff - mainly teams, outlook and excel. Been absolutely fine, crisp display with sharp text
Good chance it's capacitors of monitor's power supply which are at fault.
Those are the compoments used as failure timer.
If there's electronics hobbyer in area, might be good idea to have him take look.
Assuming power supply is internal and not disposable external power brick.
