2nd Monitor suggestions??
6 Jan 2010
I'm looking for a 2nd monitor to compliment my trusty sm2494hm, should be 24" full HD around the 200ukp mark - any ideas my good friends?? :)
I did have a 22" Samsung as a 2nd monitor but sold it on about a year ago :/
Regards, Kieran. :)
Hi kieran.gb.
Please give your signature a bit of a tweak.
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
