2nd Monitor
6 Dec 2003
Burton on Trent
I'm looking at getting a second monitor. I have a Dell Ultrasharp 24" I bought a couple of years ago, can't remember the model number.
I didn't really want to spend £465 on the Dell U2410.
I run my current monitor at 1920x1200 using a GTX470 card.
What would be the best monitor to look at, at around the £200 level and would running the second monitor at 1920x1080 cause any problems.
Thanks for you're thoughts
Steve
Any thoughts out there !!
Will I notice a big difference in quality with the £200 monitors compared to my Dell, popped into a certain shop today, and the picture on all the monitors was awful, could have been the sourse material they were playing.
Hi there,
May I ask what model Dell Ultrasharp 24in you are running?
With a £200 budget I would suggest looking at this monitor to run alongside a Dell 24in, it uses a VA panel and gets a decent write-up.
As for running a second monitor with a different resolution, it will run fine, just set it to "Dualview" mode in the Nvidia Control Panel.
