Hi All,
I am wondering if you guys can give me some help with this one as I was trying for several hours last night to get this working with no joy. The setup i have is as follows;
BT Homehub 5 (FTTC Main Router) >>> (LAN Port to LAN Port) >>> TP Link WDR4300 with DD-WRT Firmware (2nd Router).
I have configured the Homehub to use the range 192.168.1.1 with a subnet of 255.255.255.0 and a DHCP range of 192.168.1.64 to 192.168.1.253.
Basically all I want to do is connect the TP Link via a network cable and have it running OpenVPN so I can connect certain devices round the house to its wifi and be running over a VPN. I just need some advice if this is even possible and what would be the best way to configure it?
Not sure if I should be connecting Homehub LAN to TP Link LAN or TP Link WAN to start off, should i leave DHCP disabled and run the TP Link in the same range as the Homehub?
I have tried all sorts of combinations and OpenVPN either doesn't connect or any connected devices still show my Homehubs public IP?
Any help will be greatly appreciated.
Thanks, Sam.
Thanks, Sam.
