2p coins now worth 3p
14 Apr 2003
Deepest Yorkshire
Britain's 2p coins are now actually worth 3p - thanks to the soaring price of copper.
Any 2p coins made before 1992 are now more valuable as scrap metal than loose change.
Earlier 2p coins contain 97% copper which has hit an all-time record price of $8,000 a tonne.
It means that 145,000 2p coins would be worth £2,900 at the bank - but about £4,400 as scrap.
One penny coins from the same period are also worth roughly 50% more than their face value.
in 1992, the Royal Mint introduced new 1p and 2p coins made of steel with just a thin copper plating.
http://www.ananova.com/news/story/sm_1838153.html?menu=
:D get saving!
Ive got a friend who works with pipes etc - he strips old pipes of copper on the side from work and makes over £200 a week doing it!
+44
the only problem about this is its against the law to deface coins with the queens head on, defacing coins is illegal sadly :/
+44
My friend is a heating engineer, more commercial stuff.
He sometimes gets to scrap copper immersion tanks!
It sounds like an easy way to make cash - I think he's saved something like 8k towards his first house!
+44
actually, about 3 years after parliament put this through, they out another law through that made that one null and void.
effectively, you can deface the queens face on a coin without fear of repucussion.
FordPrefect said:
How long before the government "introduces" new 2 and 1p coins to get all of the old ones handed in?
Er - did you get beyond the first sentence of the original post?
Steel is worth next to nothing, as any scrap dealer will tell you.
M
