Hi guys,
Little question for those in the know about memory; I'm running 4GB of OCZ Low Voltage Gold, but I'm struggling to get it to run 8-8-8-24 as advertised, even with a voltage bump to 1.75v (which I'd rather not do long term!)
Seems quite happy at 9-9-9-24, and I may well call it quits at that, since my PC is otherwise running fine - but I've noticed a default 1T command rate, whereas nearly every screenshot I see on here has 2T. My little grey cells suggest there might be a reason for this...
Is it likely to be this that's holding me back, and if so, is 8-8-8 at 2T better or worse than 9-9-9 at 1T?
Thanks in advance
Thanks in advance
