2TB PCI-e 4.0 NVMe M.2 - Drive
2 Feb 2009
Hi all, i'm looking to buy the following drive,
However in the short to medium term, before a new motherboard is purchased, i want to use it in a PC that only has SATA connections, is this ok to use?
thanks for the help..
Don't think you can put a NVME drive in the IcyBox, pretty sure it is for M.2 SATA drives only.
Correct. From the specs listed:
- Base: B key
- M.2 card size: 22x 30/42/60/80
- M.2 connector: SATA III (AHCI)
- Supported M.2 cards: M.2 SATA B key/ B+M key
NVMe won't fit as the adapter doesn't have M key so a good safety feature.
- Base: B key
thanks.. will get an adapter from somewhere else..
