- 17 Apr 2007
Hi all
I have had my computer for about 18months, originally i had only 1 XFX 7800 GTX card at the time beacuse it cost me £350 from overclockers and i couldnt afford two. I have since brought another 7800 GTX but a Gigabyte one and attempted to set them up to run together using my Gigabyte GA K8N Pro SLi motherboard (I managed to pick the card up MUCH cheaper this time!).
I know very little about computers and the like so please forgive my ignorance, i hope this is something simple that i have missed!
I opened the computer up, flipped the "sim card" over on the motherboard to read SLi ready and added the second card, then the bridge and finally the metal brace which keeps the bridge in place (i also put power to each of the cards from my power supply). I powered the machine up and it seemed to work fine, i ran 3Dmark05 however and scored less than i used to with only one card... Also i have recently upgraded to Vista 64bit and my windows experience index dropped slightly on the graphics front...
I have uninstalled and re installed what i believe to be the correct Nvidia Drivers and have selected the SLi option in the control panel but still no joy.
I only have one game installed on my PC at the moment which is S.T.A.L.K.E.R and although it ran fine with only one card now all i can see on the screen when i go into the game is the sky with nothing else on the screen.
Any advice would be much appreciated, is this something i could do my self or should i just admit defeat and take it to a shop?
thanks in advance!
thanks in advance!
