2x keyboard and mouse?
12 Oct 2003
Is it possible to use two keyboards and two mice, one set being wired and the other wireless?
Also would there be any problems, like would it be best to get similar types from the same company?
Thanks
Yes it should be entirely possible although not using both at the same time, it may be easiest if you connect one set to the PS2 ports and one by USB but both by USB should work as well.
yes it is, and no there shouldn't be any problems, at least with windows XP :)
I normally have a wired keyboard plugged into my PC, in addition to a wireless keyboard and mouse set (Logitech desktop MX), and recently due to problems with the mouse had an intellimouse explorer also plugged in (and for a few minutes had an MX3000 set also plugged in:p).
The only problems you might get are if you knock the mouse, or leave something on the unused keyboard (happens to me quite regulary), or if you install software for two different keyboard/mice you might get a conflict.
Cool, i had a feeling it would be possible. :)
I have logitech for my wired set, im hoping to find a cheapish wireless set because it wont be used very often, any recommendations?
Thanks again!
